Deflector Chain and Cable
4 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
ツール
以前、このデバイスの修理に使われていた一般的な工具です。修理過程において全部の工具が必要とは限りません。
モデル
9270-02-01
Background and Identification
The Little Wonder Optimax GX270 Blower is a walk-behind blower designed for moving stubborn debris, standing water, preparing asphalt or flat roofs for resurfacing, or any job that requires strong air. Walk-behind blowers are used to clear roads, rooftops, and other flat surfaces of dirt, debris, and standing water. They discharge air horizontally at ground level with significantly greater force than handheld leaf blowers.
The Little Wonder Optimax blowers feature large rectangular discharge chutes with adjustable deflectors to more effectively direct air currents for clearing debris. The Little Wonder Optimax GX270 Blower includes a solid-steel construction and split-stream air deflectors that are designed to blow air faster and farther. The blower includes remote discharge chute adjustment and a transport bracket that allows for tie-down during transport.
The Little Wonder Optimax GX270 Blower includes a Honda GX270 General Purpose engine. The model GX270UT2 displaces 270 cubic centimeters (cc) and produces a net power output of 8.5-horsepower at a speed of 3,600 revolutions per minute. The GX270UT2 model’s smaller sibling, the GX200UT2, produces 5.5-horsepower at 3,600 revolutions per minute. The engine produces a net torque of 14.1 foot-pounds at 2,500 revolutions per minute. It can hold up to 5.6 quarts of gasoline and 1.16 quarts of engine oil. Honda recommends using unleaded 86 octane or higher fuel for this engine.
The Little Wonder Optimax GX270 Blower includes the name “Little Wonder” in bold capital letters at the front of the blower’s body. The GX270 engine is placed directly above the blower’s rear wheels.
Technical Specifications
- Engine: Honda GX270
- 8.5 HP @ 3,600 rpm
- Starter: Recoil
- Displacement: 270 cc
- Fuel Capacity: 1.4 Gal.
- Air cleaner: Dual element
- Low oil sensor
- Weight: 142 lbs
- 2260 cfm
- 143 mph airspeed
- 17-inch blade steel reverse angle impeller
- 25.8 sq in discharge chute
- Integrated front discharge
- Dimensions: 43” x 28” x 58”
- 10” pneumatic front tire
- 12” pneumatic rear tires
