2 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
モデル
Y6020-WK
Background
The Husky Air Compressor Y6020-WK is a portable air compressor intended for use in various settings such as homes and workshops. It is used to power pneumatic tools and accessories. The compressor is equipped with a 2 HP electric motor and has a tank capacity of 6 gallons. It can deliver a maximum pressure of 135 PSI and possesses an oil-lubricated pump. The power source for the compressor is corded electric, operating at 120V. The compressor has two quick connect couplers for easy hose connections and its dimensions are 24 x 15 x 25 inches. It weighs 71 lbs.
The Y6020-WK air compressor's compact design includes two 10" wheels and a fold-down handle for easy transport. The compressor can be used for various tasks, such as inflating tires, powering nail guns, airbrushes, and other air tools. These tools can be utilized for a range of projects in home improvement, automotive work, and hobby projects. Its oil-lubricated pump ensures reliable performance and reduced noise. The 6-gallon tank capacity offers longer continuous use of air tools, making this portable compressor suitable for small shops, garages, and home DIY uses.
Technical Specifications
- Model Number: Y6020-WK
- Product Type: Air Compressor
- Power: 2 HP
- Tank Capacity: 6 Gallon
- Max Pressure: 135 PSI
- CFM @ 40 PSI: 5.3 CFM
- CFM @ 90 PSI: 4.6 CFM
- Pump Type: Oil-lubricated
- Power Source: Corded Electric, 120V
- Number of Outlets: 2 Quick Connect Couplers
- Dimensions: 24 x 15 x 25 inches
- Weight: 71 lbs
Warranty
The Husky Air Compressor Y6020-WK comes with a 1 year limited warranty. This warranty typically covers defects in materials or workmanship. If any such issues arise within the warranty period, the consumer is eligible to claim the warranty. To claim the warranty, one would usually need to provide proof of purchase, such as a sales receipt, and contact the manufacturer, Husky Tools, with a detailed description of the issue. The company will then provide instructions on the next steps, which may include returning the product for repair or replacement.
