フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
モデル
DSH 600-X
Background and Identification
The Hilti DSH 600-X Cement Saw is a concrete gas saw released from Hilti in 2018. It has a compact and portable design, while still achieving a cutting depth of up to 120 mm. The device’s blade stops in less than 10 seconds once turned off, increasing both safety and efficiency. The Hilti DSH 600-X Cement Saw has a variety of applications, including laying paving, masonry work, metalwork, construction work, and sewage work. Essentially, this tool can be used to cut curbstones, paving slabs, steel pipes, brick walls, and concrete walls in a variety of contexts.
For added specialization, Hilti sells custom blades for the DSH 600-X, including diamond blades optimized for cutting asphalt, steel, metal, etc. Hildi also offers various accessories for the 600-X, including a self-priming pump, portable water supply tank, tool set assembly, and maintenance kit.
The Hilti DSH 600-X Cement Saw is designed to be hand-held. It has a handle, a device body that houses internal components, and a large 12-inch cutting blade. It is primarily red and black in color. The Hilti logo and the words “DSH-600X” are printed in white on the side of the device.
Specifications
- Dimensions: 22 x 12.8 x 14.6 inches
- Cutting Depth: 120 mm
- Blade Size: 300 mm
- Disc Diameter: 12 inches
- Motor Cylinder: 63.3 cm cubed (63 cc)
- Power: 3.2 kW
- Maximum Spindle Speed: 5,500/min
- Carburetor: WT-1203 (Walbro)
- Engine Type: Single-cylinder, two-stroke, air-cooled
- Maximum Engine Speed: about 9350 rev/min
- Spark Plug: CMR7A-5 (NGK)
- Fuel Mixture: 50:1 (2% oil)
- Tank Capacity: 29.4 ounces
