67 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
ドキュメント
モデル
BRD-280
Background and Identification
The ECHO Bed Redefiner BRD-280 is a flower and mulch bed maintainer that is designed to redefine garden beds. The BRD-280 model has a five-year consumer, two-year warranty. The edger can cut up to 3.8 inches deep.
The ECHO Bed Redefiner BRD-280 includes a 28.1 cubic centimeter professional-grade, two-stroke engine. The machine’s engine produces less than one horsepower. ECHO recommends using a 50:1 ratio of fuel to oil mix for all two-stroke cycle engines (50:1 ratio is equal to 1 gallon of 89 octane fuel and 2.6 fluid ounces of oil mix). Use a mid-grade to premium gasoline with a minimum octane rating of 89 or higher. The BRD-280 model can hold up to 21.1 fluid ounces of fuel and includes a 59-inch shaft and a six-finger, carbine-tipped steel blade. The steel blade is designed to be replaceable.
The BRD-280 model can be identified by its orange and black engine cover and handle. The manufacturer’s name, “ECHO,” is printed in black font near the bottom of the shaft and in white font on the side of the engine cover. The machine’s fuel tank is a partially-transparent white color. A high-impact nylon shield is attached to the bottom of the shaft to protect users from flying debris.
Technical Specifications
MPN: BRD-280
UPC: 743184994351
Manufacturer: Echo
Engine Type: 2-Stroke
Fuel Tank Volume: 21.1 fl. oz.
Edger Cutting Depth: 3.8 in.
Weight (lbs.): 18 lbs.
Warranty: Consumer Warranty: 5 years | Commercial Warranty: 2 years
Engine Size: less than 1hp
