4 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
モデル
DXPW4240
Background
The DeWalt DXPW4240 is a pressure washer that operates on gasoline. It is equipped with a 208 cc 4-cycle OHV axial cam pump engine that provides a power rating of 4200 PSI and 4.0 GPM water flow. The fuel tank of this device can hold up to 1.1 gallons of gasoline. It also comes with a high-pressure hose that is 25 feet long and a soap tank with a capacity of 1/2 gallon.
This pressure washer is designed with five different quick connect spray tips (0°, 15°, 25°, 40°, 60°) made from stainless steel to cater to different cleaning needs. It has pneumatic tires and a steel frame that comes with an integrated hose reel and onboard storage for keeping nozzles and accessories. Some of the other features include a detergent tank, insulated high pressure trigger gun, garden hose connector with water inlet screen, and a 12V battery charging port. Regular maintenance is required for optimal performance of this device.
Technical Specifications
- Model Number: DXPW4240
- Product Type: Pressure Washer
- Engine: 208 cc 4-cycle OHV axial cam pump
- Power: 4200 PSI
- Water flow: 4.0 GPM
- Pump Type: Axial cam
- Power Source: Gasoline
- Fuel Tank Capacity: 1.1 gallons
- High Pressure Hose Length: 25 ft
- Soap Tank Capacity: 1/2 gallon
- Dimensions: 30" x 19" x 37"
- Weight: 99 lbs
Warranty
The DeWalt DXPW4240 pressure washer comes with a limited 3-year warranty provided by DeWalt. This warranty covers defects in materials and workmanship on all major components of the product. However, it's important to note that normal wear items such as nozzles, hoses, and filters are not included in the warranty coverage. To claim the warranty, the customer must provide a proof of purchase and have registered the product.
