2 の図表
ドキュメント
モデル
BTFP02011
Background
The Bostitch BTFP02011 is a 6-gallon portable air compressor. It was introduced in 2013 by Bostitch, a subsidiary of Stanley Black & Decker, as part of their line of portable air compressors. The product operates at a maximum pressure of 150 PSI, delivering air at a rate of 3.8 SCFM at 90 PSI. The compressor is oil-lubricated, powered by a 120V electric source, and produces 82 dB of noise. It measures 22.2 x 10.1 x 23 inches and weighs 64 lbs.
The BTFP02011 is capable of powering various pneumatic tools such as nailers, staplers, spray guns, impact wrenches, ratchets, drills, and sanders. Its compact design includes an integrated top carry handle and front-mounted wheels for easy mobility. The unit has a high-flow regulator for improved performance of air tools and a ball valve for quick tank drainage. It's primarily intended for home DIY projects, vehicle maintenance, and use in small workshops or garages. The compressor can be used for driving nails and staples, HVLP spray painting, air brushing, tire inflation, abrasive blasting, and air tool operation. Introduced in October 2013, the BTFP02011 replaced the previous BTFP02006 model, featuring a larger tank capacity and higher air delivery. As of 2023, the BTFP02011 is still in production.
Technical Specifications
- Model Number: BTFP02011
- Product: Bostitch Air Compressor
- Product Type: Air Compressor
- Tank size: 6 gallons
- Max pressure: 150 PSI
- Air delivery: 3.8 SCFM @ 90 PSI
- Pump type: Oil-lubricated
- Power source: 120V electric
- Noise level: 82 dB
- Dimensions: 22.2 x 10.1 x 23 inches
- Weight: 64 lbs
Warranty
The Bostitch Air Compressor BTFP02011 comes with a 1 year limited manufacturer's warranty. This warranty is designed to cover any defects that may occur in materials and workmanship within this period. However, it's important to note that this warranty is confined to the repair or replacement of defective parts and does not extend to issues that arise from misuse or normal wear and tear. To claim the warranty, users are advised to refer to the included documentation that provides the full terms and conditions.
