1の図表
ドキュメント
モデル
LDX120C
Background
The Black and Decker Drill and Driver (model LDX120C) was released in 2015. It is a cordless power hand tool that operates on a 20-volt lithium-ion battery, which can retain a charge for up to 18 months. This device includes an 11-position clutch designed to reduce the possibility of stripping or overdriving screws. Additional features include an LED light for improved visibility in dimly lit work areas and a compact, lightweight design that allows use in confined spaces. This tool is primarily intended for general home improvement tasks.
Key components of the LDX120C include the 20V maximum battery back, battery release button, variable speed trigger, forward/reverse control button, mode selection collar, 3/8-inch keyless chuck, charger, and bit holder.
Consumer feedback has noted some issues with battery charging, clutch performance, and chuck reliability. There are no manufacturer recalls reported for this model.
Identification
To identify the Black and Decker Drill Driver model LDX120C, you will notice the distinct orange and black coloring around it. It has ergonomic rubber gripping making it easy to hold. The LED light is built-in located above the trigger. The 11-position clutch is numbered around the drill. The battery is located on the bottom of the device and labeled with lithium 20V. The dimensions of the device are height is 7.7 inches, length is 9.4 inches, and width is 2.6 inches. This is a compact design that weighs 3.3 LBS with a maximum of 650 RPM.
Source:
20V MAX* Cordless Lithium Drill/Driver
Technical Specifications
- App Compatibility: No
- Battery Included: Yes
- Battery Qty: 1
- Battery Type: 20V MAX* Lithium Ion
- Battery Warranty: 2-year limited
- Battery Amp Hours: 1.5 Ah
- Charger Included: Yes
- Charger Type: Wall Mountable Charging Base
- Charge Time: 60
- Chuck Size: 3/8 IN
- Chuck Type: Keyless
- Cordless Vs Corded: Cordless
- GTIN: 00885911235822
- Max RPM: 650 RPM
- Motor Type: Brushed
- No. Of Batteries Required: 1
- Product Application: Drilling
- Height: 7.7 IN
- Length: 9.4 IN
- Weight: 3.3 LB
- Width: 2.6 IN
- Voltage: 20 V
- Watt Hours: 26
- Warranty: 2 Year Limited Warranty
- Includes:
- (1) Lbx20 20V Max* Li-Ion Battery.
- (1) Lcs20 Charger.
- (1) Double Ended Bit.
- (1) Ldx120 Drill/Driver.
- * Maximum initial battery voltage (measured without a workload) is 20 volts. Nominal voltage is 18.
