Buttons on the side of the brush
サポートに関する質問
質問する質問はありません。 最初の質問をしてみましょう!
ツール
以前、このデバイスの修理に使われていた一般的な工具です。修理過程において全部の工具が必要とは限りません。
Background and Identification
The Apalus Digital Hair Straightening Brush is an electronic hairbrush that is designed for straightening and detangling hair. It can be identified by model number HC002. The brush is designed for users with wavy or thick hair. It features dual-voltage operation support for either 110 Volts or 240 Volts. The brush can heat up to 365 degrees Fahrenheit in one minute. When the brush’s power is on, the temperature will be displayed on the device’s LED screen.
The brush produces a maximum heat of 450 degrees Fahrenheit. The automatic setting keeps the brush at a constant temperature of 365 degrees Fahrenheit for all types of hair. Users can customize the temperature settings; Alapus recommends a setting of 410 degrees Fahrenheit for natural texture hair and 450 degrees Fahrenheit for thick or wavy hair. Users can perform deep care with oil treatments for their hair using the brush at 125 degrees Fahrenheit. The brush is designed to prevent scalding and damage to hair.
The Apalus Digital Hair Straightening Brush features a U.S. safety plus, short-circuit protection, leakage protection, and automatic shut-off protection if the brush is not in use for 60 minutes. If traveling internationally, the brush requires an extra international power plug adapter.
To change between Centigrade and Fahrenheit, press the “+” and “-” buttons at the same time.
