メインコンテンツにスキップ
Model A1046 or A1095 / 1280x854 screen resolution
164の回答 すべて表示
Sold Wrong DC Inboard
Hi, I just purchased a new DC Inboard because mine was loose in the area where the adapter plugs in. The seller sent me the wrong part giving me Part #A1095 instead of part #1046.
After changing a couple of the cables around we were able to get it all connected however it doesn't work. This was my main computer so I know it worked just fine when I was able to charge my battery on a friends computer.
Right now it charges the battery, but just makes a whirring sound like a car does when the battery is low. No chime or anything else.
My question is after I return the board should I try to find the right part or does it sound like something else is now wrong with my baby?
Thank you!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
Wait till tomorrow for an answer from Ben Eiseman. He's the best parts man around here.
この回答は役に立ちましたか?
スコア 3
コメント:
Thanks Mayer for your suggestion. I've put the old board in and it does light up the power plug, the problem is the adapter part is loose, but I will see what happens when I reconnect the logic board.
による
コメントを追加
Try and put the old board in, and see if you can get it to boot, if this doesn't fix it, you may have roasted the logic board. These boards put out a specific voltage for the right laptop, and the wrong board could cause some damage.
この回答は役に立ちましたか?
スコア 1
コメント:
Thank you for your answer. I really have nothing to lose at this point so I'm going to give it a try!
による
コメントを追加
The board will work fine in the A1046 and A1095 . I successfully tried it dozens of times.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
N Little さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 820
