How do I install a new Airport card?
Hi all,
I have a Macbook Pro A1286 and I can't seem to find any directions on where to replace the module. A picture is all I would need to see where I need to replace it.
Thank you,
Jase
この質問は役に立ちましたか?
Hi all,
Thank you,
Jase
この質問は役に立ちましたか?
Start by choosing your machine the guide will give you plenty of pictures as well as list of tools - the job is always easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
I followed the guide choosing MacBook pro mid 2009 and did not see a guide for replacing airport card
このアンサーは役に立ちましたか?
Opps! The team forgot to make a guide for this exact model. Not to fear! The older model is the same.
Here's the guide you need to follow: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement. I'll warn you this is a big job! You may want to find a good used display assembly and just swap out the whole assembly.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,968
