Apple hardware test Failure code...
After running a aht it gives an error : 4SNS/1/40000001: VP0R-0.000
what is the exact problem in this logic board. System is very slow . i already dismantle 3-4 times some time after assembly it works for little time means working until restart. after restart it again giving same problem.
この質問は役に立ちましたか?
3 件のコメント
If i Plug the Charger in then the laptop works fine no problem. while on charger also AHT gives same error . What to do??
SIMRAN さんによる
I see two possibilities; use it as is, or, replace the logic board.
originalmachead さんによる
What did you do in the end ? I have exact same problem. Dont no weather to get fixed or not ?
Raymond Moran さんによる
