メインコンテンツにスキップ
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
53回答 すべてを表示
a Fujifilm FinePix S5 Camera lens Stucked could be fixed?
It has a problem with the Lens, it is stocked, apparently one of my kids dropped it and it got stocked
5.1 MP Digital SLR Camera
Or Where can I send a Fujifilm FinePix S5200 to repair?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Miguel J, this is one of the most common errors with digital cameras. For some of the better ideas on how to fix it, check this site. Of course, you can disassemble the camera and make sure that all the ribbon cables are connected, also check for loose or broken contacts. One more possibility would be to replace the lens assembly, and it is not a terrible job. You can get the service manual from here. You could check for a quote from places like this, or id you are somewhere in the UK from here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Miguel J さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,935
