メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1623回答 すべてを表示
Where to replace stripped MacBook 2012 screw?
Believe it or not... I've already stripped a screw trying to remove the bottom of my 13" MacBook Pro (mid-2012). I'm going to buy the Moody's extractors I've seen mentioned on here, but where can I get replacement screws?
I only need one of the longer screw length. I'm open to buying a full set, though, seeing as I still have to remove the case without stripping any additional screws.
Thanks for the help!
-Brian
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This is the DIY volunteer forum, not iFixit Customer Support. They can tell you if 2011 screws will work, if they have them and if they'll sell you less than a set. You may as well order the special tools required as every job is easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian Sharon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 946
