Black Screen DFU iPhone 4, Error 1601/1602 on Restore
I have an iPhone 4 that is stuck in DFU mode and will not restore through iTunes. The following are the processes I've tried to get the iPhone 4 to restore. All are performed with firewalls turned off.
Restore Process 1
1. Backup hosts file. Do not replace.
2. Use iReb to enter Pwned DFU.
3. iTunes restore 5.1.1.
RESULT: 1602
Restore Process 2
1. Create custom 5.1.1 IPSW using redsn0w
2. Enter Pwned DFU using redsn0w
3. Shift-click restore to custom in iTunes
RESULT: Hangs up on "verifying with Apple" 1602
Restore Process 3
1. Insert "74.208.10.249 gs.apple.com" in hosts file
2. Enter Pwned state with redsn0w
Result: Hang up on "verifying with Apple" 1602
Restore Process 4
1. Put phone into normal DFU mode
2. Normal iTunes restore
Restore Process 5
1. Remove hosts file.
2. Enter recovery mode (screen is black, so I'm not sure of recovery vs. dfu)
3. Normal iTunes restore
RESULT: Hang up on "verifying with Apple" 1602
Restore Process 6
1. Create custom 5.1.1 IPSW using sn0wbreeze
2. Start TSS Server in tinyUmbrella and select Upgrade iPhone 4 baseband
3. Enter Pwned DFU with iReb
4. Custom restore from sn0wbreeze using iTunes
RESULT: Hang up on "preparing iPhone for restore" 1601
I also tested the battery voltage at 3.8 volts. Any ideas?
is your phone currently on 5.1.1?
Brent Huff さんによる
Not sure. It came to me in this horrible condition.
Rand Lemley さんによる
