メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
The display on my iPod is blurred?
for a while i had problems with my ipod. half of the screen was unresponsive to any touch but i left it . after being cracked & quickly fixed at a non-apple store it had a little opening gap between the upper left side. i was messing with it & squeezed it down pretty hard & when it got back on the screen was more as fizzed out like a tv screen. the side that wasnt working is still unresponsive to touch & i have the additional problem to the color & display. any one know how much it could cost it be fixed? or how i can?
https://discussions.apple.com/message/19...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
sarah, it sure looks like you need a new display assembly. The unresponsiveness is from a broken digitizer circuit and the distorted image is a broken LCD. Check here for the guides. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Had a similar issue with mine, the display was flickering regardless of pressure on the back. i swapped the screen myself for under 60 bucks with no issues sense. I got mine from here.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sarah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,112
