メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1623回答 すべてを表示
Why is the via connection to my MacBook Pro 2012 not working?
I tried to connect my macbook pro 13 to a projector and i get only vertical lines on the screen. I used the apple recommended Mini-display port/thunderport adapter to VGA but nothing works out. Any info is highly appreciable.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Try changing the resolution & cycle settings of your laptop. Projectors have (and you must know) resolution parameters or limits. Refresh rate Hz cycles also must match. I would imagine that if the external video is not showing up in System Preferences:Displays window you have either a resolution/cycle matching problem OR a connector/adapter problem.
There is a "detect displays" button in System Preferences to use if connecting the cables/adaptor doesn't automagically find a second display.
If this answer was helpful please remember to return an mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
If VGA shows nothing...Plug in the VGA cable to the projector and the adapter. Then, close the Mac book while powered on, causing it to go into sleep...Plug in the adapter and open the mac book back up. It should work...thats what I have to do if I want to use VGA... My Mac book freezes when I plug in the VGA adapter with the screen open...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rajesheber さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,157
