What to do when my screen stay white?
Even after a restart, my screen stays white, should I ship him to apple or someone got any other idea?
Dominic, for what it will cost you to ship it to get repaired, you might as well do it yourself. I would start by opening it up and checking the display connector. the white screen only means that the backlight is working, no data. If your cable and connector are okay, replace the display. Not a bad job, but it will require you to properly identify your iPod. the displays are different even so the task is the same. Use the guides from here to get it done. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 451
Depends on what type of iPod do you have, which one do you own?
John Smith さんによる
Ipod classic 5th or 6th generation
Dominic さんによる
