iPhone charges while switched off but not when switched on?
I have a strange problem with my iphone 4s. It doesn't charge when it is switched on but it charges when it is switched off.
that its not the right way to go to DFU mode, if you want to put your device in DFU mode just follow this steps. plug your iphone on the pc or mac then press and hold the power and home button for ten seconds, then release the power button while holding the home button and wait the confirmation for the itunes your phone is in recovery mode. and you will recognize your screen goes black. no itunes logo nor cable logo. if you can see the itunes and cable logo, your on a recovery mode. its not DFU mode.
このアンサーは役に立ちましたか?
Perhaps it happens because enters in DFU mode directly.
Or perhaps you have jailbreaked your iphone.
Do this steps:
1.- Do a backup of your personal data and software if it can be done.
2.- Turn of the phone
3.- Plug the usb apple cable to your computer.
3.- Keep pressed the ([]) central button and plug the usb cable to the iphone.
It should enter in DFU MODE showing the itunes logo and the USB PLUG with an arrow.
Start Itunes and perform an iOS UPDATE.
Good Luck!
このアンサーは役に立ちましたか?
that's not DFU mode.
yups not in DFU mode
its also charging really slow
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 6,890
3 件のコメント
Keyrun Adhikari さんによる
(bump) do to having the same issue
_Z_ さんによる
yups, i also have this problem. even changed the new power dock and battery. only charging when off. also cannot detect itunes when in switch on.
ejeler さんによる
