メインコンテンツにスキップ
The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
26回答 すべてを表示
What's the best option for a quad core G5 with lack of upgradeability?
I have a G5 OS X Leopard. I been trying to figure out how to maximize the machine since I cant upgrade to any of the newer iOS. Is there any software that allows you use it as back up storage for current Sever OS? Thanks in advance for any input.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Take the HD out and put it in an external case. Then you can use TimeMachine or any 3rd party software you'd like. You could also purchase OS X server an run it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Boot the G5 in target disk mode it will act like an external HD - AFAIK to do this you have to connect them both via Firewire - if your other Mac doesn't have Firewire you'll have to put the drive in an external USB case. Then sell the machine as is or for parts.
If this answer was helpful please remember to mark it accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
The G5 tower can be networked with the iMac. If you are running PowerPC programs (in 32bit), you may even use it as part of a render farm (ie. with older versions of AfterEffects, FCP, or Compressor).
As stated by MacHead3, you can start the G5 Tower in target-mode and use its' drives as back-up storage. (That still seems like a really big external drive).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
I have a mid 2011 imac 27" i5 but use my late 2005 G5 quad networked as both a back-up and spare. Firewire 800/400 connection may even be better given sufficient space. The iMac had a major issue with a faulty HDD but I enjoyed using the G5 again. Only trouble is the legacy applications are getting harder to find for PPC Leopard or Tiger. So it's even more important to keep a back-up of that too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Bordeaux さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 385
