Is this water damage? Related question: is this cable toast?
この質問は役に立ちましたか?
Yes, this is indeed signs of corrosion caused by the salt in the water or chemicals from the liquid, you can try cleaning it up with some 99% ISP, but in my opinion is is wise to change the cable as it does appear to be damaged or melted in some areas, the cables pins also look burned.
このアンサーは役に立ちましたか?
The connector is in worse shape, likely need to replace it.
@livfe @danj Right, Hmm, I did clean the board a while ago with IPA, though not anywhere near 99%, probably ~70% I would guess (it was several weeks ago).
I updated the post with a current pic of the connector. I guess I could stand to clean up the board a little more, but can you tell any better if the connector needs to be replaced?
@agitatedgopher - The damage on the cable also reflects onto the pin within the connection. Sadly the connector is not designed to be taken apart to check. At this point is a coin flip, see if the replacement cable works.
Cool. Since it doesn't look like ifixit has that cable, is there a place online to order specific components like that? Or should I just check with local repair shops?
@agitatedgopher Just google for it.......
過去 24時間: 4
過去 7 日: 4
過去 30 日: 16
今までの合計 116
