How can I fix my power cord
My power cord will no longer charge my MacBook
この質問は役に立ちましたか?
Early troubleshooting coming up:
このアンサーは役に立ちましたか?
First i would have to ask if you can turn on you MacBook while is pulled in, if so the charger itself is fine. The problem would be in the battery. If it will not power up while pulled in you would need to test it with a volt meter to see if it supplying power or not. If it is supplying power then the problem lies in the computer and there are many guides to help you repair it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 851
1件のコメント
Is the cord broken somewhere? Or are you just not able to charge anymore?
Michael Stoffer さんによる
