メインコンテンツにスキップ
The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
26回答 すべてを表示
締切られた回答
cd rom opens when the system is starting
I have problems with the cdrom, always starting the same when it opens the cdrom tray. replace the cd rom and continues to open whenever the beginners
Update
hello problem fixed
I used the mouse that made ​​the cd rom open
the mouse is fine however does open the cd rom
and then removed without opening starts now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
I suspect the eject button on your keyboard is being pressed or is stuck.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It might be an uncompleted backup program that wants to write to a disk and is "helping" you remember by opening the optical drive door.
さんによる
コメントを追加
Power off the computer.
Disconnect the rodent.
Startup the computer.
Problem gone when rodent disconnected?
Holding down the mouse button at boot time will eject any CD
left in the drive....so a broken/iffy mouse button can cause this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
it can also be from some settings in the startup menu when you boot your computer. When they ask to press F12 or something at the boot to open some settings. I am not a computer wizard, so i do not really know if there is such a setting, but it would be my guess
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not on a Mac, they have a dedicated key, no f-keys.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,241
