メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kia Sportage SLシリーズは2010年4月にアジアおよびヨーロッパ市場で発売され、続いて2010年8月に北米および中央アメリカ市場で2011年モデルとして発売されました。
кия 2013 пали трудно ,когато е топла
когато е топла , пали трудно .кия 2.0 бензин
Translation Bulgarian - English
The 2013 Kia is hard to start when it's warm
When it's warm, it's hard to start. Kia 2.0 gasoline
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@hristoelefterov there are simply too many possibilities that could be causing this. The best starting point is to scan your Kia's OBD-II system for any stored trouble codes; keep in mind that codes can be present even if your Check Engine Light isn't turned on.
Hard starting when the engine is hot typically points to issues with the electrical components or the fuel delivery system. Try these to see if you can narrow it down:
  • Don't overlook the simple things—inspect your spark plugs and ignition coils for proper function first.
  • Test the crankshaft position sensor, as heat frequently causes internal sensor degradation and erratic signaling. Additionally, clean both the throttle body and the Mass Air Flow (MAF) sensor.
  • Check the fuel injectors and verify that the fuel pump is maintaining proper pressure, as high under-hood temperatures can sometimes cause fuel vapor lock.
  • Check the engine's compression. If compression readings are excessively high when warm, you may be dealing with a mechanical issue related to the valve train or the camshaft positioning.
You can download the SM or the 2.0 Sportage from this page 2011-2015 Kia Sportage under the Documents header. It could help you to work on all of those issues.
Let us know what you find out!
Translation
@hristoelefterov – причините за този проблем са просто твърде много. Най-доброто начало е да сканирате OBD-II системата на вашия Kia за налични кодове за неизправност; имайте предвид, че кодове могат да са налице, дори ако индикаторната лампа „Check Engine“ не свети.
Трудното запалване при загрят двигател обикновено сочи към проблеми с електрическите компоненти или системата за подаване на гориво. Опитайте следното, за да видите дали можете да стесните кръга на възможните причини:
  • Не пренебрегвайте простите неща – първо проверете дали свещите и запалителните бобини функционират правилно.
  • Проверете датчика за положението на коляновия вал, тъй като топлината често води до вътрешно износване на датчика и нестабилни сигнали. Освен това почистете както корпуса на дроселната клапа, така и датчика за масов въздушен поток (MAF).
  • Проверете горивните инжектори и се уверете, че горивната помпа поддържа правилното налягане, тъй като високите температури под капака понякога могат да причинят блокиране на горивните пари.
  • Проверете компресията на двигателя. Ако показанията за компресията са прекалено високи при загряване, вероятно имате механичен проблем, свързан с клапанния механизъм или позиционирането на разпределителния вал.
Можете да изтеглите SM или 2.0 Sportage от тази страница 2011-2015 Kia Sportage под заглавието „Документи“. Това може да ви помогне да работите по всички тези проблеми.
Уведомете ни какво сте открили!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Христо Елефтеров さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 73
