A P0420 code means "Catalyst System Efficiency Below Threshold (Bank 1
How to fix it
@tejpal89202 there are a few things that could cause this The most common one is a failing catalytic converter. It can also be caused by an exhaust leaks, or a bad downstream O2 sensor, intake air leakage etc. Use the 2014 Nissan Maxima Engine Controlchapter form the SM and go to page 304. Here you'll find what to check and how to diagnose and ultimately proceeed to get this fixed. Let us know if you need more help on this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 34
