Laptop won't come on
My laptop is fully powered, battery charged and pluged in. when I press the power button the green power light comes on for about 4 seconds then clicks
Off.
aaron, remove all of your RAM and try to start your laptop. It is possible that bad ram is preventing it from starting.
このアンサーは役に立ちましたか?
Strip down your computer to check one by one and I also doubt that your power button has might come up however you can try cleaning using isopropyle alcohol. Hopefully that will work for you.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 852
