メインコンテンツにスキップ
ヒューレットパッカード(HP)は1993年よりパーソナルラップトップコンピューターの製造を開始しました。
2299回答 すべてを表示
締切られた回答
Hp dv6 1308EL stuck on HP Invent screen
Hi all,
I've had a problem with my notebook.
I've unmounted it to change the thermal paste on CPU and GPU, and now when I power it it gets stuck at the HP Invent screen for a loong time.
How can I fix it?
I've tried to change the thermal paste again, and it was ok.
I've resetted the CMOS
I've tried separately the two RAM cards
I've tried to boot it without the hdd
BUT nothing happened..
Even the BIOS screen, when I manage to get to it, it's veery slow, I can barely navigate in it..I've resetted the Bios settings, but still nothing..
Help me please, I'm going crazy!
And I forgot to tell that the first time I booted it, it worked fine and I used it for a few hours and it was going just fine!
After I restarted it, with no updates, it didn't boot anymore..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Slow BIOS navigation? Check that thermal paste again, sounds like overheating. If you are not sure what good thermal paste connection should look like, put some on a flat piece of metal, and smush it with another piece of metal. Also, check to make sure that your Heatsink os properly vented, and that dust particles are not blockin the airflow.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 734
