メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The park does not shut radio off when door is opened. How do you fix
Car not acknowledging when the car is in park, the car is shut off and door is opened. Radio stays on and the p of park is still lit on the gear shift.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @jolenercrane
Seems like there may be a problem with the Retained Accessory Power (RAP) system in the car.
One of the features of this system is that the radio will continue to play for some 10+ minutes after the engine has been turned off and the ignition key is removed from the key lock. It should stop when the driver's door is opened though
Does the driver's door ajar indicator light in the instrument cluster turn on when the door is opened? I'm not sure if the ignition key needs to be in the ignition key lock or not for the light to work.
Do all the things you mentioned disappear if you don't open the driver's door for about 10-20 minutes after turning the engine off and removing the key from the ignition key lock i.e. radio turns off and Park gear shift light disappears?
If there's no door ajar indication when the driver's door is open and the radio and Park light do turn off after 10-20 minutes when not opening the driver door then it could be a problem with the driver's door sensor switch.
If the door ajar light does turn on and off when the door is open and closed then it could be a problem with relay RLY01 (RAP relay) in the Instrument panel fuse block or the BCM (Body Control Module)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jolene R Crane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 45
今までの合計 314
