メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and disassembly information for the Victus series of gaming laptops by HP.
It isn't charging
I tried charging the laptop but it won't charge and the small indicator isn't turning on too
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@nakshatrar you are not telling us if your computer still turns on and works when the AC power adapter is connected. It will also help if you can give us the complete model number for your Victus laptop.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc., with a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger.
After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. iFixitでの質問に画像を追加する方法
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nakshatra. R さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 41
