メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2189回答 すべてを表示
iPhone will not Scan for WiFi, etc.
No MiFi address (or other) visible. Phone gives "Could not scan for wireless networks." How do I fix this, or is the iPhone defective? It's barely 2 mos. old:-/
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
First hold the home and sleep/wake button for 10 seconds until the iPhone turn off completely. This will fix most common errors. If that doesn't work then try backing it up the restoring it from your computer. If both of these methods do not work then I would take it to Apple to see what they can do. If it is 2 months old then there will still be a warranty on the iPhone.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
If you have tried repairing this device yourself, such as replacing the display assembly or even just changing the battery, the oil from your fingers can interfere with the wifi antenna which is exposed massively even if you just take away the back case.
Remember you only need just one digit in 20,000 '1' s and '0' s in wifi signals to be missing for your iPhone to think the signal is so corrupted (so weak) that it will not be able to see the device. Try using a degreasing agent.
Apple products are to a certain extent assembled by hand, so it is not surprising if one has been defective and is seen from very early on.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Clovis Gentilhomme さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 15,976
