メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
After driving on LPG, engine cannot run again for a while
I have mazda 626 lx 1998 lpg/gasoline. Initial ignition is always on gasoline and after start I can switch to LPG. Problem started recently when I drive on LPG and off the engine. After that I am not able to run it again for a while. This is usually happened during summer time. Seems to me that need to wait some relay to be opened and gasoline come to the engine. Anyone can help me with advise
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
The original fuel pump relay is located in the relay box which is right next to the battery. The exact location within the box should be printed on the relay box cover.
You should test to see if it operating and sending power to the fuel pump. It is controlled by the Powertrain Control Module but I am not certain how the original gas controls interact with the LPG controls.
BILL
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
There are two relays MAIN RELAY (B5B418811) and Z5A118821 which is relay for fuel pump. I found location of main relay but not sure for the location of relay for fuel pump.
さんによる
コメントを追加
回答を追加する
Goran Cabrilo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 434
