メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月20日に発売されたAppleのフラッグシップスマートフォン。5.8インチのOLEDディスプレイ、トリプルレンズリアカメラを搭載し、バッテリー駆動時間が大幅に向上しました。iPhone XSの後継モデルです。
Why is the screen turning off after a few days?
I’ve replaced my iphone 11 pro screen, loud speaker, and battery. Everything is normal but after 2 days the screen went black but the phone vibrates/plays sounds when plugged in. The only fix to this is unplugging the battery’s flex cable then the lcd turns back on. This cyle went on three times then Ive tried another lcd but the same issue persisted. Im at a loss, what could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
If the phone still vibrates and makes sounds but the screen randomly goes black, and it only comes back after disconnecting the battery, that usually points to a board-level issue rather than the display itself, especially since you already tried another screen.
On the iPhone 11 Pro this can be caused by a failing display power line, a short around the backlight circuit, or a power management issue triggered after the repair. It can also happen if there’s slight damage near the display connector or a component was disturbed during the battery or speaker replacement.
If it turns on long enough, check Settings > Privacy & Security > Analytics & Improvements > Analytics Data and look for panic-full logs. You can upload those to an online panic log analysis tool to see if there are display power or PMIC-related crashes happening before the screen cuts out.
Since swapping the LCD didn’t fix it, this is likely a logic board fault that needs microsoldering repair rather than another parts replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most likely something to do with the proximity light sensor not functioning properly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Khian Lolong さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 38
今までの合計 298
