water damage, won't turn on
Hi somebody,
My canon was dunked in water and after drying it out the camera makes no function...
how many fuses are and where they are?
Thaks,
Vidma
この質問は役に立ちましたか?
Hi somebody,
Thaks,
Vidma
この質問は役に立ちましたか?
vidma, the image will show you where the power fuse is located. Just remember that with water damage, a good cleaning with isopropyl alcohol is a must. Otherwise, you run the risk of corrosion failure later on. Here are more reason why your camera may not get any power:
"If electrical conduction is not found:
• FUSE is blown; replace it with a new one.
If the FUSE is not faulty:
• MAIN PCB Assembly excluding the FUSE is faulty
• OPERATION FPC Assembly is faulty
• TOP COVER UNIT is faulty
• BATTERY COVER is damaged.
• DETECT SWITCH(MAIN PCB assembly) is faulty"
Hope this helps, good luck
このアンサーは役に立ちましたか?
Hi oldturkey03 I replaced the main then also cam is not getting on.where can I get all cam spares.plz help
canon sd 1100 got dunked in juice , cleaned with ip also replace fuse 1001 then also not getting 8n plz help.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 2,430
6 件のコメント
Have you disassembled and cleaned it yet?
oldturkey03 さんによる
Hi oldturkey03, Thanks for the very fast and full-scale response!
I"ll try a bit later.
vidma
vidma さんによる
the FUSE was not faulty,
I cleaned with alcohol, shorted the SWITCH on battery door, but still nothing.
Think stray current made more serious damages :(
vidma さんによる
vidma, try to clean the logic board with with isopropyl camera. There are a few more fuses on the logic board. Check all those for continuity.
oldturkey03 さんによる
Thanks oldturkey03, but how to find them, could you send me service manual with repair instruction and diagrams?
vidma さんによる
1以上のコメントを表示
