メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
replacement battery not staying charged and fan running
Hi I replaced the battery, and it doesn't seem to be detecting it. If I unplug it from the wall it shuts down, also the fan is running and has not ever stopped. I have had it plugged in to the wall for several hours now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@kristinam66215 - Let's give this a try to see a bit deeper into the problem. Install this gem of an App CoconutBattery let's see what it tells us, take a snapshot of the Apps main window and post it here so we can see it as well.
さんによる
コメントを追加
1 件の回答
if you see an 'X' or nothing at all where the battery icon is in the top menu bar this will confirm the battery is not being detected. In system profile under 'power' it should be displaying the battery info, same with CoconutBattery,. Carefully go over the battery replacement guide as it seems to be that the battery is not fully connected, this will cause the unit to go into a safe mode in which the fans will spin more to prevent overheating. Ensure that there are no bent or damaged pins and that the cables are fully inserted and latches are locked.
MacBook Pro 13インチ Function Keys 2017 バッテリーの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kristina M さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 16
今までの合計 30
