メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
46% battery in my M1 with light use, what went wrong?
Hi everyone,
I’m hoping to get some perspective on what might have caused my battery to degrade this much.
Model: MacBook Pro 13" M1 (2020)
I bought it on the second day after launch and maxed it out.
Mostly web design work, around 5 hours on weekdays. I’m usually in Safari/Chrome/Edge, some Photoshop, and After Effects only once every few months. It’s never really overheated, and in real life the battery still lasts over a day, which is why the “maintenance” warning caught me off guard.
Battery health:
  • macOS says 62%
  • CoconutBattery says 46%
画像
画像
画像
I stayed on Sequoia 15.6 for about a year, then updated about 4 months ago to 15.7.2 (24G325).
  • Usually kept it between 20–80%
  • Never left it charging overnight
  • Plug it in when doing heavier tasks
  • I Always used it indoors, never really traveled with it
  • Surge protector
  • 25°C and 40°C all year but I only use it inside, AC on
I honestly planned to use this machine for 10 years. Performance-wise it still feels basically new, so I’m confused about what I did “wrong” with the battery—especially since my iPhone and iPad from around the same time are still sitting around 80%.
I’m already planning to bite the bullet and pay for an official battery replacement, but I wanted to ask here first:
Does this kind of degradation seem normal for an M1 Mac after this many years?Could heat or being charged in a lot of times (+500s) have sped things up?I
Thanks for any thoughts or experiences.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sadly, cycle count is not the only way to measure batteries life. Age and over tethering to AC outlets. Here the battery is 5 years old, if you tend to leave the system plugged in (on or off) most of the time then the battery doesn't get a chance to discharge (which from your description is not an issue). It's also been found not exceeding 80% charge offers better life. Review your battery's setting to see if you can set it or download the App which can override the OS. Lastly, you could have just gotten a weak battery🙁.
Here's the needed part MacBook Pro 13" (A2159, A2289, A2338) Battery and here's the guide to put it in your self MacBook Pro 13インチ Two Thunderbolt Ports Late 2020 バッテリーの交換
Replace a battery compatible with MacBook Pro 13" (A2159, A2289, A2338). 58.2 Watt Hours (Wh), 11.41 Volts (V).の画像
製品
$99.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you so much!
Yes mine does have the 80% setting and I have an Automation notification set up too, my 2020 ipad is still going strong using the same kind of care/surge protector. Thank you for the guide
さんによる
@beaglecoconut I have seen batteries die on MUCH lower cycles, 5 years is a long time for any re-chargeable battery, 80% charging or full charging makes for no real difference, just how it is.
さんによる
コメントを追加
Hi,
Apple says the a battery can last up to 500-1000 cycles and most MacBooks go beyond the 1000 cycle mark and still having a decent amount of health in the battery.
But
There are some exceptions an some batteries fail before the 500 cycle mark without a clear explanation.
You are better if you replace your battery to avoid complications like swollen battery or further degradation , when your battery does not hold any charge and the Mac turns off when unplugged.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you, yes I plan do get a new one as soon as possible. My mac still lasts about 1 full day of work but I dont want to risk it. Bad luck then, 562 cycles :/
さんによる
コメントを追加
回答を追加する
Coconut さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 25
今までの合計 263
