What Voltages on connector of main board for backlight 55" Jvc?
LT-55N780A
Can someone tell me what voltage I can inject with a variable PSU to test the backlights please?
Set powers on but black screen. No backlight no picture.
Update (01/29/26)
I have the back cover off it and there are no lights showing thru the small holes that light usually shines thru, as in back light.
I have seen them light up before and work but they might have been damaged when I was playing around with the TV.
No audio.
I don't have aerial connected.
I suspect the power board and that's why I would like to know what voltage I can inject to see if the back light is there.
Thanks for your input.
この質問は役に立ちましたか?
1件のコメント
Hi @ric81505
Just verifying that with the TV turned on, you can't see any images on the screen (probably very faint if they are there) when using a flashlight held at an angle close to the screen to hopefully see them, is this correct?
If you can't then it could be more than a backlight problem e.g. tcon, mainboard or even screen
Is there audio heard when the TV is on?
What is the model number of the TV?
jayeff さんによる
