メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides, disassembly, and troubleshooting information for the Beelink Mini S13 (N150) mini PC, released in early 2025.
How to remove the motherboard
I can remove the cover on the bottom and remove the 4 screws of the motherboard.
So far I was unable to remove the motherboard from the case, because it seems the HDMI and USB connectors are stuck in the holes of the case.
Do I need to bend something or is there any additional screw etc. still attached, which needs to be removed?
I want to remove the motherboard, because the CPU fan is very loud and I want to make sure the fan or heatsink is not dirty or thermal paste needs to be exchanged.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi, you can refer to this MINI S12 teardown tutorial: https://url.bee-link.cn/F5R9
If you need any further assistance, please feel free to contact our support team at support-pc@bee-link.com. We'd love to help!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the info, I guess that helped.
It would be helpful, if you put that video on YouTube or any other video platform, so users don’t have to download a 1 GB zip file just to watch a 3min video.
さんによる
コメントを追加
Don’t bend anything. On most laptops/mini PCs, the motherboard won’t lift straight up because the HDMI/USB ports are keyed tightly into the rear I/O cutouts. After removing the visible screws, double-check for hidden screws (often under stickers, rubber feet, or near the fan). Also disconnect all ribbon cables (fan, power, speaker, Wi-Fi antennas) before lifting. To remove it, gently slide the motherboard sideways (toward the front) to free the ports, then lift it out at a slight angle. For the loud fan, clean dust with compressed air and replace thermal paste if it’s dry or cracked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sim さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 76
今までの合計 230
