メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A1708/EMC 3164 — 2017年6月にリリースされたこのエントリーレベルの MacBook Pro は、(OLED Touch Bar とは異なり)従来のファンクションキーを備えています。
What if I broke the clip on the sister ribbon connector
as I was replacing the battery I accidentally pulled the sister ribbon off on both ends. As I was trying to reconnect it I think I broke the cable latch on the big side. It isn't detecting the battery, it will not hold a charge and will not work if unplugged from the wall and the fan stay on the whole time also the key board isn't working . I took it to a repair shop and they said they reconnected it with the old ribbon and told me that the new ribbon that I purchased from Ifixit wasn't the correct ribbon. She told me that I would have to keep it plugged if I want to use it and that I would need to use an external key board!! Well this is the reason I replaced the battery as it wasn't holding a charge unless being plugged in. Maybe I messed it up - wondering if I just need to ditch the project and buy a new one...not really in my budget but I need a working lap top
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@kristinam66215 let's see what the damage looks like. Post a couple of well focused pictures of that with your question so we can see what you see. iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
From your other note it sounds like the Zero Insertion Force (ZIF) cable connectors latch was lost. Review the steps 11& 12 in this guide MacBook Pro 13インチ Function Keys 2017 バッテリーの交換to verify that they are both present. The do need to be present and set as they compress the cable to create the needed connection.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kristina M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 111
