メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
初代Xboxは、Microsoftで初めて広く普及したビデオゲームコンソールです。上面と前面に「XBOX」の文字が入った黒いケースで、簡単に識別できます。修理は一般的な工具で簡単にできます。
Shuts down after 5 minutes
Original Xbox 1.6 – Persistent ~5-minute shutdown on two separate motherboards
Symptoms:
Boots normally, fan spins, runs for ~4–5 minutes then hard shutdown (power cuts off completely).
Fast alternating orange/green flashing LED the whole time.
Same exact behavior on two different version 1.6 motherboards (Tuscany).
No HDD or DVD drive connected (minimal PSU + board only test).
Troubleshooting already done:
Replaced thermal paste on CPU & GPU (old stuff was cracked/shrunken). No change.
Fan confirmed working normally.
Swapped power supplies (tested with known-good PSU). Same shutdown.
Measured resistance on 12V yellow wire to ground: 0.557 MΩ (no short).
Observed 12V rail drops to ~5V right at shutdown.
Clock capacitor not bulging; no visible leakage/corrosion near it or Xyclops.
No bulging/leaking on any electrolytic caps (including five 3300µF ones near power/CPU/GPU).
Not using original AV cable (none plugged in during tests) → explains orange/green flashing ("no AV pack detected"), but shutdown persists.
Tested with no peripherals; same result on both boards.
Conclusion so far:
Not PSU, not thermal paste/heatsink, not obvious cap failure, not HDD/DVD, not simple short. Seems like false overheating protection (integrated temp sensing in Xyclops chip) Xyclops/temp diode path
Traces look good
Update (01/19/26)
Ive also confirmed from what I can see traces are good
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
⚠️ Known Weaknesses of Xbox v1.6 Boards
• Xyclops chip (video encoder + system management)
• Integrates temperature sensing and shutdown logic.
• False triggers are known if the temp diode path is degraded.
• Capacitors
• Even if not visibly bulging, the five 3300µF caps near CPU/GPU and the smaller ones in the power regulation path can dry out internally.
• Aged caps can cause voltage sag under load → explains your 12V rail dropping to ~5V at shutdown.
• Trace corrosion
• Clock capacitor leakage is infamous on earlier revisions, but even if yours looks clean, micro‑corrosion under solder mask can affect sensor lines.
🛠️ Next Diagnostic Steps
1. Check voltage regulators
• Measure 5V and 3.3V rails during operation. If they sag before shutdown, suspect caps or regulators.
2. Replace suspect capacitors
• ESR meter test is best, but given age, replacing the 3300µF caps and smaller filter caps is often necessary even if they look fine.
3. Inspect Xyclops temp diode path
• Look for hairline cracks or corroded vias around the Xyclops chip.
• Reflow solder joints if needed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jason Kelly さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 86
