メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display、モデル番号A1502は、第5世代のIntel Core i5およびi7プロセッサを搭載し、Force Touchトラックパッドを導入しました。
Weird Keyboard Behaviour after laptop in box fell down...
2015 A1502 13" retina Pro. New Battery, 90% charged & New TP + Cable.
Laptop was secure in its original apple box complete, working fine.
Box fell down 1.5m from the shelf. Nothing came out, box stayed closed.
Opened it up, all components intact, nothing lose or fell out.
KB Connection reset correctly a few times. Latch is secure. Keys all working.
I swapped out the TP & Cable 2x with other new components and all is functioning fine when the laptop is powered up. But, it will only power up when connected to the charger. Has the fall somehow broken the KB power button?
Scratching my head as this is an odd one...... PRAM reset completed.
I tried adding US KB layout and back to ABC biu it didn't help.
CAPS lock and KB power button no function & the /// key adjusts the KB backlight, - key dims down th KB backlight, F1 does volume down....... Input source is ABC and it is a fresh install Monterey. KB is suddenly defective ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
Did the Battery shift?
さんによる
@danj Nope, battery never moved..... I am changing the keyboard in it as I type, I put the battery into another unit and it is working perfectly. It can only be the KB has done a funny one.....
さんによる
@livfe - I think the battery shifted pressing on things to damage.
さんによる
@danj Battery was stuck down, never moved, even if it did what could it have pressed on to damage? Only the TP cable... but I have changed that and a TP and they function OK... Just Power button no effect and some keys performing different tasks as mentioned. Very weird.... TP is protected by a plate that would withold any battery movement.... only the cable I can think of could have been affected. All conections on the board are intact, nothing appears to be damaged.
さんによる
Keyboard is out, almost all the rivets remained..... punched them out, drilled a small hole for the screws... not a single screw wants to get home :( Nightmare ..... Anyway, New KB all OK.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I replaced the keyboard and everything is now working fine, so the issue must have been keyboard related.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Its the best solution.
For cheaper equipments just replace it instead of finding out soltion. Hahaha..
さんによる
コメントを追加
回答を追加する
livfe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 79
