メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年9月16日発売、6.1インチProMotion OLED、トリプルレンズのリアカメラシステム、5G、前面カメラとトップセンサー周辺の新デザインDynamic Islandなどが特徴のAppleの小型版フラッグシップスマートフォンです。iPhone 13 Proの後継モデル。
iPhone 14 Pro Stuck in Apple Logo Boot Loop
I have a question about the Apple logo boot loop on my iPhone 14 Pro. The symptom is a loop interval of about 3 seconds. After looping around 20 times, it enters recovery mode.
Yesterday, I left my phone untouched for about an hour after using it, and when I checked it again, it was powered off. When I turned the power back on, it fell into the Apple logo boot loop.
I don't have a backup and don't want to factory reset it. I have already tried a force restart, OS recovery preserving data via 3uTools, and Fix Flash (both iTunes mode and 3uTools mode), but the issue wasn't resolved.
I suspect it might be related to the proximity sensor. What do you think?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Looping after 3 seconds is usually a power issue. Replace the battery
さんによる 共有
@imicrosoldering Do you have a source?
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
A 3-second Apple logo boot loop on an iPhone 14 Pro that eventually drops into recovery mode is very unlikely to be caused by the proximity sensor—that component is only initialized later in the boot process and normally wouldn’t prevent iOS from loading. Given that the phone powered off while idle and now fails to boot even after a data-preserving restore and Fix Flash, the symptoms point more strongly to a hardware fault, most commonly the power management IC, logic board instability, storage (NAND) errors, or a failing battery or battery data line. A repeating short boot cycle often indicates the phone is failing hardware checks during early boot and restarting as a safety response. Unfortunately, if recovery-mode restores that preserve data cannot complete, software is largely ruled out, and factory reset would be the last software test—but if that also fails, professional board-level diagnosis is required. If your data is critical, take it to a reputable microsoldering repair shop that offers data-preservation repairs, and avoid further flashing attempts to reduce the risk of permanent data loss.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Well you can checkout the following video; https://www.youtube.com/watch?v=5h1xSqEg...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
To confirm whether it is the proximity flex just disconnect it and the phone should then turn on. You may need to use 3uTools to kick it out of recovery mode. If it does turn on the phone will restart every 2-3 minutes without this flex connected. Once you replace it with a woking flex then it will work fine again without any restarts.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Am a new repair technician and I want more knowledge about it pls help me
さんによる 共有
コメントを追加
回答を追加する
what さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 32
過去 30 日: 149
今までの合計 1,508
