メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo IdeaPad 1-15ALC7は、日常的なコンピューティング向けに設計された15.6インチのノートパソコンです。AMD Ryzen 7000シリーズプロセッサを搭載し、ストレージのアップグレードも可能です。モデル:IdeaPad 1-15ALC7。
Backlight not working what do I do
recently my laptop had fallen off my bed when I woke up and it knocked the screens loose from the part connecting my screen to the actual computer and now the screen turns on however you need a flashlight to do see anything? What do I do
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi @seanmcgowan
In order of best case to worst case possibility:
  • Loose EDP cable connection on the motherboard or the LCD screen.
Here's the hardware maintenance manual for the laptop. Go to p.53 (59 of 66 pdf) in the manual to view the procedure to remove the EDP cable. This will allow you to check if it is still securely connected to the motherboard. On p.50 (56 of 66 pdf) it shows how to remove the LCD screen. You don't have to remove the LCD screen, just check if the EDP cable is secure.
  • Damaged EDP cable where it passes through the hinge from the lower case to get to the LCD screen in the lid.
If the cable is damaged search online for 5C10S30543 (touch screen) or 5C10S30353 (non touch screen) to find suppliers that suit you best.
Here are some images showing the relevant schematic for the backlight power circuit and also the boardview showing the location of the fuse as it possibly won't be marked on the motherboard.
画像
画像
entire board view showing where the fuse is
画像
zoomed in view showing the fuse location in more detail
(click on images)
  • Faulty LED backlight circuit in the LCD screen.
If this is the case, the screen will have to be replaced as it cannot be repaired. Usually the Lenovo part number for the LCD panel can be found on the back of the panel. Search online for the part number, to find suppliers that suit you best. The HMM shows how to remove the LCD panel
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
You are a life saver. I routed the cable wrong and it got pulled when closing the laptop causing the fuse to blow. I thought I had ruined the new screen.
thank you so much for the schematics
さんによる
コメントを追加
Your laptop likely has a damaged or disconnected display backlight, which is common after a fall. Since the image is visible only with a flashlight, the screen itself is working but the backlight or its cable is not. First, power off the laptop and avoid using it further. If you’re comfortable opening it, check the display cable near the hinge—it may be loose or partially unplugged. If reseating the cable doesn’t help, the backlight or inverter (on older models) may be damaged. In most cases, the fix is replacing the screen or display cable at a repair shop.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If your screen only works with a flashlight, the backlight or screen cable is likely damaged. It’s usually not something software can fix, so professional repair is the safest route.
さんによる
コメントを追加
回答を追加する
Sean Mcgowan さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 83
今までの合計 548
