メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bosch RS325は、さまざまな用途での切断に対応する、軽量かつコンパクトな電動のこぎりです。120V・12Aの出力、毎分0〜2,800回の無負荷ストローク数、一定のオービタルアクション、可変速トリガーを備えており、素材に応じた精密な切断制御が可能です。本体サイズは長さ17.8インチ(約45.2 cm)、重量7ポンド(約3.2 kg)で、ソフトグリップハンドル、安定性を高めるフット、簡単に交換可能なブレードホルダーなどの特長を備えています。
Why did my saw lock up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@drew70414 we need more details. Locked up how and what have you already checked?
さんによる
コメントを追加
1 件の回答
Hi @drew70414!
Based on the common mechanical design of the Bosch RS325 and similar reciprocating saws, your saw likely locked up due to one of three main issues: a jammed blade clamp mechanism, internal gear failure, or motor obstruction.
Here is a breakdown of why this happens and how to troubleshoot it.
1. The Blade Clamp is Jammed (Most Common)
The RS325 uses a quick-release collar system to hold the blade. If this mechanism gets clogged with debris or if a blade breaks off inside, it can seize the entire reciprocating shaft.
  • The Cause: Sawdust, metal shavings, or a bent blade fragment can get wedged in the "collar" (the part you twist to release the blade).
  • The Fix:
    • Inspect the collar: Look for a broken piece of blade stuck deep inside the holder.
    • Lubricate: Spray a penetrating lubricant (like WD-40) into the blade holder and let it sit for a few minutes to loosen any gunk or rust.
    • Force Release: While unplugged, try to rotate the collar back and forth firmly. If the blade is still attached, you may need to tap the blade gently with a hammer or use pliers to wiggle it free while holding the release collar open.
2. Internal Gear or Bearing Failure
If the blade clamp is moving freely but the shaft itself won't move (reciprocate), the issue is likely inside the front gear housing.
  • The Cause: The "wobble plate" or reciprocating gear that converts the motor's spinning motion into the back-and-forth cutting motion may have broken or jammed. This often happens if the saw was pushed too hard during a cut or hit a nail, causing a sudden stop.
  • The Fix: This requires disassembly. You would need to remove the front rubber boot and the screws on the gear housing to inspect the gears. If you see shredded metal or a gear that has jumped its track, the saw will likely need professional repair or replacement parts.
3. Motor Obstruction or Brush Failure
If the saw hums but doesn't move, or makes no sound at all, the lock-up might be electrical or magnetic.
  • The Cause:
    • Debris: A small rock or chunk of material may have fallen through the air vents and wedged itself between the motor's armature and the magnet, physically stopping it from spinning.
    • Carbon Brushes: If the carbon brushes (which conduct electricity to the motor) are worn down or broken, they can sometimes jam the commutator.
  • The Fix: You can check the brushes by unscrewing the brush caps (if accessible on the side of the body) or opening the rear handle housing. If a piece of debris is jamming the motor fan, shaking the tool vigorously or using compressed air might dislodge it.
Quick Safety Check: Always ensure the saw is unplugged before trying to pry a stuck blade or disassemble any part of the tool.
If you meant something else, hit me up.
Best wishes
Marvin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
drew さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 85
今までの合計 497
