Camera will not turn on
Camera will not turn on. I have replaced the battery and it still does not turn on. Next steps?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Val, time to take it apart and check the battery connections. Make sure they are all in good working order. Check the bottom of the battery door, make sure that it pushes the battery so as to make connection with the battery connectors. Of course, make sure that you connectors are not corroded. The only other things you can try and check, but you will require a multimeter for it, are the 1.25A 32V fuse F8001 on the logic board, or the regulators IC 9001 and 1002. I attached part of the schematic that shows the voltages. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,378
