メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
Why is my digitiser uncalibrated after replacing it?
Iphone 3gs 16gb.
I replaced the digitiser and front glass (1 piece) put it back together, it detects my touches so is working, but thinks I am tapping about 1cm to the left of where I actually am tapping. Is there a way to calibrate the touchscreen like on many phones or have I done something wrong? I know this is a known issue, but there doesn't seem to be any up to date information or definite answer :( any help would be very appreciated as I'm doing it for a friend and I can't imagine them being 100% happy with this fix as only the outer glass was broken when they gave me the phone! thanks, max
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
You either have a faulty digitizer or, more likely....
You have a faulty mainboard connector. The first iPhone I ever looked at was this way, and I needed to have the iPhone looked at. It ended up being that the connector could not be fixed to resolve the issue. Again, you are looking at a bad mainboard digitizer connector (#2). It may be fixable, but it may not be.
Best of Luck,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
having same problem did you need a new glass?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 627
