Why the saw can run but there is no cutting strength
The saw can run but when cutting something it has not powerful enough, no cutting strengths.
This is what AI has to say using a simple search: A 12A AC motor lacking power can be caused by electrical issues like low voltage, open windings, or a bad capacitor, as well as mechanical problems such as worn bearings, overload, or a lack of lubrication. To diagnose the issue, check the power supply, test the windings and capacitor, and inspect the bearings for proper lubrication and free movement. I would start with a capacitor if it has one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 13
