メインコンテンツにスキップ
Epson EcoTank L3150 Wi-Fi All-in-One Ink Tank Printer
Why doesn't it print blue, but instead turns it red?
The blue colors don't print and turn red. I want to know if there's a problem or what.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The printer won't print at all if there's an empty ink cartridge, (but a low magenta cartridge MIGHT be the problem.) It's probably either an issue with the color management settings or clogged print heads... so check the ink levels and also try running the print head cleaning routine (multiple times if it improves but doesn't go away with a single run). If the printer sits for too long without being used it tends to have problems with the ink drying out on the print heads and clogging them.
Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bashar Alhamody さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 16
