メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
Is my laptop done for?
Would you get this repaired or opt for a (new to me) refurbished laptop? I dropped my laptop one time recently and the one corner dented in pretty bad and the screen has some cracks. The display connection has been ruined and I just get a black screen with a little light on the cracks. What would you do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You decide: parts available here, click "parts" at the top of the page or just browse from the link below:
Replacement Screen alone is $500...
Now, that might be all you MUST replace, but that can only be determined by opening it up to find out what else is damaged.... And your personal preferences... The degree of damage to the case is unclear, as "pretty bad", means very different things to different people. If it is cosmetic only, and you can live with that, maybe you won't have to fork out more than that screen cost... But... It's possible that it's also got other things wrong with it inside that we can't know about yet. Some of these (possibly damaged) things might be expensive and /or difficult to repair. There are more parts available here, you can add up the numbers of what you can tell you need, ballpark the numbers for the things that might be... But the only way to get a good idea is to get the puppy open and look, there's also the question of whether you can afford either option.... And whether you want to dive into the repair yourself... And whether you can get the repair done by someone else for a reasonable price are all stuff you need to weigh. The model page has guides to help you. Go For It!
If you decide to go for it, and need more help, just take photos of what you want advice on and ask, people will be happy to help you!
Good luck.
Replace a display compatible with a model A2338 MacBook Pro 13" laptop. Includes the 2560 x 1600 pixel IPS panel with True Tone, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism.の画像
製品
MacBook Pro 13" (A2338) Display Assembly
$494.99
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I should mention that if it works fine with an external monitor, it is a very good sign that all you need is the new screen as far as internal damage... so try that. Sadly it is not possible to replace ONLY the bad parts in the screen assembly... the parts are sold as single modules to ensure that repair is as expensive as possible to 'encourage' you to buy a new one instead... (environmentally conscious of them, yes?) that's the current "repairability" of the company's products. I, for one, detest the practice... but it is what it is.
さんによる
@uchetil - Recovered used display assemblies are cheaper and reduces by one new part need from the factory saving the environment a bit!
As an example MacBook Pro 13" Complete Display, Silver (M1 2020/M2 2022) : Grade-B depending on your MacOS release you might be able to reenable TrueTone! Apple now offers within their newest MacOS a way now to add replacement parts back in!
さんによる
@DanJ,
Good advice, I never actually work on Macs so I'm not up on the current parts availability, Thanks!
さんによる
@uchetil - You took care of the question quite well! Here's a good used parts house in the UK I often use for Mac parts TheBookYard
さんによる
コメントを追加
回答を追加する
Alexa Pavan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 68
