メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sonyのワイヤレスノイズキャンセリングオーバーイヤーヘッドホン「WH-1000XM4」の修理・分解情報です。
XM4 stopped powering on — still works with 3.5mm.
My Sony XM4 suddenly stopped powering on — no LED, no response even after charging for hours and trying resets.
However, it still works perfectly when plugged in with a 3.5mm audio cable.
I also confirmed there's no issue with the USB cable — tried multiple cables and chargers, still no sign of charging or power.
Has anyone experienced this? Is it likely a dead battery or a charging IC failure?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi there, I experienced something similar but had some lights come on, I was wondering if you have tried this.
Why are don't my headphones turn on and instead factory reset?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Good troubleshooting info - and your guess is the most likely the answer.
Disassemble and check battery - most likely
Other than that, it is likely not repairable unless you can find a simple component failure like a diode or transistor.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hiii!!! I found the issue of the device currently the headphones working without an issue
Ill explain what was the issue so in the charging PCB a IC has blown up so the device detect charger is plugged only when the device is switched on and as i can remembered last time i fully drained the battery and because of the charging PCB IC issue the battery did not start charging
I guess now i might have to replace the charging PCB of the device 😢
さんによる
コメントを追加
回答を追加する
Asyad Nazeem さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 24
過去 30 日: 77
今までの合計 918
