メインコンテンツにスキップ
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25回答 すべてを表示
Where to buy replacement batteries for flip minoHD
Hello I have a couple of flip mino hds that i have taken apart and I have tested all the batteries and they are all dead. When I attach a working battery from different mino it works fine! Anyone know where I can find replacement parts?
I have tried batteries plus and called flip. batteries plus could not find a replacement and flip told me they do not sell replacement batteries for the mino as it is an internal battery.
Please if anyone has any advice it would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
It might be possible to replace the battery, but to keep the case and circuit board. Do you have a part number on your battery?
さんによる
コメントを追加
7件の回答
最も参考になった回答
Hi,
I've found a source of the battery (only large quantities from this supplier). Does anyone know how the PCB controller attached to the Flip Mino battery might be reused? The original is spot welded.
I'll bet there are lots of these cameras out there that could be saved if we could figure out how to safely install just a new battery in this recorder.
Here are the data on the battery and it's supplier:
Lithium ion Sanyo 553450 UF553450Z battery cell
Part Number: 0204-0019-00
Model Number: 1UF553450-1-T0423
http://www.alibaba.com/product-gs/349657...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Part:http://www.amazon.com/Flip-Video-Ultra-R...
Best of Luck,
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks but this is not the battery for the minoHD.
Does anyone know if it is possible to buy a regular li-ion 3.7 v 1150mAh battery and install the board from the old pack onto it?
さんによる
Unfortunately, that was the only battery on the market. Unless you buy a used or broken one, and transfer the battery, there is no other way to do so.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
さんによる
Battery for Palm One LifeDrive Pocket PC seems to be an equivalent but connector needs to have four leads. Have ordered one and if it is a replacement will report.
さんによる
コメントを追加
Any more recent news on battery replacement for a MinoHD? Ours no longer keeps a charge for more than a few minutes.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
EBAY has the internal batteries for the flip
さんによる
コメントを追加
I have purchased many of these batteries here http://bestbattery.biz/Cisco/221946-F460...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do you open minoHD for changing the battery?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you need cheap and high quality durable camcorder batteries then cheak this http://broadcastbatteries.tv/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This is a direct replacement battery, with the same 4 wire connector!
https://www.amazon.com/gp/aw/d/B00ET08ZK...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ecarter1117 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 7,845
