メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
Charging light turns off after a couple of seconds, not batt prob
The 3DS will power on when plugged in, but will shut off after power is removed. I tried replacing the battery with a new one from Amazon (this) that had good reviews, and there was no change.
The charge port IS damaged, but since it turns on (and stays on) while plugged in, I highly doubt that's the problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Sounds like motherboard related. I know that the DS Lites had the EM10 filter. If that one is damaged, it also wouldn’t charge anymore.
You can try to return the battery and try a new one, but most likely this is not it.
I would also check the fuses on the motherboard, just to check if they are fine.
If you need any guide, please let me know!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
how can I check the fuses? what do they look like?
do you think I'd need to replace the motherboard?
さんによる
Hi!
They are labeled with “F”. It is explained here: https://youtu.be/cONKZqOeTJM?si=1oupwMqg...
If they are fine, I would replace the motherboard. Saves you a lot of headache. Otherwise, replace them! Soldering is required for this.
さんによる
コメントを追加
回答を追加する
Joshua Weiss さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 29
今までの合計 123
